Even the Formula S Barracudas and the 273 Commando Darts had a single outlet on the drivers side. It can be done, but you may have to do a little modification to the tailpipes.
The right exhaust pipe of a dual exhaust system designed to fit in '68 and up A-body will not fit in a '67 because of idler arm interferance.
