Brake shields. I used the 74 Imperial pieces, but they had to be cut and re-welded, (1) for a different offset and (2) one flipped as the Imperial uses the same parts on both sides, with one caliper mounted toward the front, one mounted toward the rear. While this works fine it looks odd. I wanted both calipers mouted toward the front.
