the problem i see with the other kits is that they require spacers to get the job done. Now your relying on the strength of some spaces. With the BCR kit once you install the mains, you deck the bottom of the block so the mains and block are flat. I know it seems a little pricey, but its not even close to a comparable product. I know how hard you mud guys are on stuff.... especially you....
