The only staples were in the corners where it might shrink a bit and pull loose from the adhesive. There were 3 to 5 staples in each corner.
Was that common? Should I look for a heavy duty stapler to do that again or is the adhesive better these days?
Any advice available would be appreciated. Thanks!
JK mity225@mchsi.com
With todays adhesive I would not worry about staples..
