Well
The A pillar pars is what I am worried about. I hope the fit tight against the firewall and window pillars, so a I just notch the dash and be done with it..
I also want the dash bar to be tucked under the dash, and provide a mount for the home fab'd steering column I am making.
Pretty simple and light is the main issue. I just ordered a Flaming River Universal U-Joint that replaces the old rag joint with a new joint, a piece of 3/4 tubing, etc a light weight steering wheel and wheel disconnect.
Should save 20+ lbs over the factory steering column setup
