IIRC,i thought I read to use the 3100 GM spring with the 2.2 retainers also
IIRC I talked to patrick about that when he sugested the comp 901-16 spring for my pre-mag roller set up
and the GM 3100 for a mag head
the 901's are good for an LA head where you don't have the rocker ratio, and more installed height than a mag head.
the 2.2L retainers allow you to use any single spring in the 1.4-1.45" OD range.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
