"BTW they're called Hubs"
Thanks Hemirick
I thought if I ordered new front drums that they would come with a hub also!
![](/ubbthreads/images/graemlins/shruggy.gif)
I called them back and this is the only way they sell them. Have to find the hub somewhere else. "Explain "worn out". The bearings, races and studs can all be replaced" I already have new bearings and races!
Stumpy, the bearings were making a noise and we determined that the seats of the hubs were worn too much. Thats why I ordered new drums figuring that I would only have to replace the bearings and races.
![](/ubbthreads/images/graemlins/confused.gif)
Thanks Mike
"The 11"ers will work if you swap the backing plates and everything."
Thanksfor the info Hemirick. The guy I know has the backing plates and everything to go with the 11 in. setup. Are you sure they will fit the spindles on the front?
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
If so then That is the way I will probably go since he only wants $50 for the whole front setup. I called around and they want upwards of $150 for a used hub!
Mike
