My 68 Charger's front drums are cracked. I got replacements from RockAuto.com but they come completely bare without studs or the center bearing retainer section that presses out (and presses into the new drum)and holds the bearings and races(is that called a spindle??) Does anyone know where I could get new spindles?Mine are worn out and I need them also. They are 10 in. drums.
Thanks Mike
P>S> My friend has 11 in. drums complete from his 69 Roadrunner. Will they fit my Charger?
