I just purchased a distributor on ebay item #230422363671 for my 70 Dodge challenger 440 4 barrel 4spd. After getting it I realized it might be incorrect. The red anodized tag reads the 3438222 which is correct but the date is 6 9 which in my mind is for a 69 build and the vacuum advance part # is 2642262. Does anyone know if this is correct or can I use the distributor and change the advance and put a repro date correct tag on it? I would even consider purchasing a correct one if there is one available.
