The guy I bought the wheels off of, bought the studs, and I bought them from him, along with the chrome lugs. The packaging says that they are 1/2 inch. I found a set of Moroso lugs that were 7/16 and bought those I guess they will work.
I compared the 1/2 inch lugs with the factory ones and found that the 1/2 's were bigger.
NO WAY should that car have 7/16 studs. Only the small bolt pattern A bodies came with a 7/16 stud. I sure wouldn't put a 7/16 stud on that car. Get some 1/2 inch studs with the correct knurl.
