That I can tell, there were no changes to the rear end of the door from 70-74.
The door latch mechanism itself had a (somewhat inconvenient) anti-lockout feature in 1970, while 71-74 cars did not have this. Either latch will bolt up and work without problems.
If you had them, Door edge protectors just clip on, no mounting holes required.
