Just be careful over camming the small port. In the end you may loose more down low, then you gain up top...
Yes.
The 1st cam you mentioned would definitely be on big side for your compression/heads/converter. I just replied to your PM from other day. Sorry been swamped W/ work & taking while to get PM's emails/calls done lately.
That Crower you PM'd me about would not be bad, it's still hair small but, step in right direction.
