The A990 might be a little tight, but the 65' AFX scoop will. It is a taller version of the A990. Now if you want one, don't go fiberglass, ask if Harms smith here will fab one using there A990 template. It might be expensive.
I made my own 65" AFX scoop out of aluminum and it can clear a skyscraper. It totally looks original.
