Re: What build would make the most RELIABLE 1000hp SB?
[Re: emarine01]
#579333
01/11/10 10:29 AM
01/11/10 10:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Now that's what I looking for, current build is already a Tall Alum 360 Alum mopar Block, which forces a dry sump, W-8 ported heads, then what are the most reliable endurance valves for turbo builds, max bore up to 4.180", need to decide stroke/cubes (low end is not critical, throttle response is more so), forged crank or is billet better/needed choice, I would rather limit rpms to keep reliability, rod size 2.1,2.0,1.88?, Ti rods are a consideration, roller is a definite, turbo is of course most obvious choice, but single vs dual turbos, intercooler just makes sense, but thought just maybe a Procharger type set-up might be more reliable to set-up and maintain for someone like me that knows just enough to get in trouble. As tough as it might be to finally put this package together, I am not in a position to be able to afford scattering it, hence reliability is of key importatnce in the chase for 1000 hp.
I wouldnt go the Procharger route it uses HP to make HP where the turbo is basically free... valves... a good stainless valve is plenty... no need for a Ti rod... your not spinning it hard.... a chevy rod size is fine. It sounds like you would need to get the turbo setup tuned for you but there are plenty of shops that can put it on a dyno and take care of that for you
Free....
Notice that word "basically"
