i have a 5.7 hemi and will be running the factory fuelinjection on it in my project. i was wondering what everyone uses for the fuel pump and regulator.
i have the street and performance harness and computer. they said they use a EP381 AC delco pump and 99 up camaro filter with regulator in the filter. but i seen that the autoparts store lists a regulator seperate for the camaro so i wasnt sure if it was in the filter.
just need to get fuel to it now and it should run,
thanks
