The hole in the '94 tailhousing is the same as the older cable drive, just install the cable adapter and pinion from an older unit and you will have a threaded cable adapter.
since he's keeping the EFI, he needs both the VSS output AND the cable drive....
I believe its a choice of the mechanical cable, or the electronic speed signal. I don't think you can run the Engine Controller without the electronic speed signal.
Yeah I need the electronic signal and the mecanical cable. The device I got the other day looks like this. It's a speed sensor that connects in between the cable and the speedo gear housing. It would work except the wiring harness for the 94 has 3 wires and the speed sensor I have has two. I am hoping their is a way to adapt it.
can you get wiring harnesses and find out what each wire is used for? maybe the 3rd wire is a ground that's not needed?
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
