4 decade old springs = bad idea. Even if they've never run, they've been under load for 40 years.
These will drop in and give enough load for whatever you're likely to run w/ stock heads.
Their #1105 spring would probably do well for a lot of applications, too.
When the springs are off, just make sure that the retainers won't smack the tops of the guides. That's NOT a good thing
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
