If I was in your position I would watch the classifieds here on moparts for a good used built small block motor from a member in good standing on the board here.Im sure you can stay within your budjet and get a stroker motor or at least a 340.
Lately there has been quite a few in the engines section and you will most likely get one for quite a bit cheaper than doing it your self.
