Quote: I have taped a screw driver to a broom stick and gone from inside the back seat. You need to stick the screw driver into the elongated slot and give it a turn. The trunk will pop open. A good flash light is a must.
yeah I did something like that once at the track too. I used a long stick. You just need a small enough screw driver to fit in the slot.
