I can see how one would work but would not want to step on it accidently
My trailer has a 4' beavertail so I jack the front up quite a bit and it goes in/out with no problems...
Now the TS car is a big PITA!!
My next trailer will be 2' longer, 8' beavertail with drop start axles.
that looks like something i would trip over.
my 40' trailer with 8' beaver tail, and 4' flap with 3" bumpers under door and it still won't go in. not sure what those axles are though.
I use this for my car... I have 6" bumpers on the
door which is about 6.5' tall then have 6.5' alum
ramps hinged to the door... the ramps I made have
a side wall that goes to the ground with a lip so
they stay on the surface instead of digging in. This
pic is a while back, since then the door got alum
diamond plate and 2 eye bolts (1 on each side) for
a strap to hold the ramps from swinging. I dont jack
the front up because I have a LQ up front and want
it level
