Post your results / experiences if you have used a SOLID , flat tappet Hughes camshaft .
Im looking at either the 6872BS3 or the 6468BS3 .
i will be using a 1.6 rocker and Isky 400lbs open springs
i have run that exact 268/272. the one i run now is bigger. break it in properly and don't let it idle excessively. highly recommended!!!!
