You could get either the bumblebee or the longitudinal stripe at no cost on R/Ts and A66 cars.
That's what I meant. You needed a stripe delete code to not have a stripe fitted. Which is why so many R/Ts came with one or other of the stripes. If a tail blackout was standard it wouldn't work with the 1000s of R/Ts with the Bee stripe so you would need a delete code for that too and of course there isn't one.
2002 Chevrolet Corvette 5.7 LS1
2011 Alpha Romeo Giulietta Veloce 1.6 JTD
Because running a Mopar in the UK is getting TOO expensive!!
