I'm going to say you'll be fine. I'm running the 70's smogger pistons in my 440 with the 60303 cam and it runs well. You've got to have more CR than me so in all likelyhood you'll be fine. If you knew how far down in the hole your pistons are and whether they have a dish or just valve reliefs your actual CR could be calculated.
