Re: 505 headed back to the dyno
[Re: AndyF]
#55280
03/22/08 03:49 PM
03/22/08 03:49 PM
We used the standard offset exhaust rocker arms on both the intake and the exhaust and had some custom spacers made up to center the intakes on the valves.
that's a very nice looking setup. the above statement seems alittle confusing to me though. it doesn't look like all those rockers are exhaust rockers???
what are you using to hold the intermesiate shaft in place since there's no dist. in the hole?
what dimension did you come up with for the milling of the head to accept the jesel stands. it's not like i'd probably ever do all that but it'd be great info just the same.
