I know this has been covered before but couldn't find it. My vinyl top car is in primer and I wanted to know what the finish on the roof needs to be under the top. Is sealer ok to install the top over or can I use some single stage paint left over from the engine compartment? Or should I paint it base/clear with the rest of the car and do I need to rough it up? Thanks, Todd
