The advantage to the DP is that the secondaries will open by foot, not when the engine needs it. Bigger is still bigger. On the dyno at work a 428 ford made 391 hp with an 850 dp. When I put the 950 vac secondary carb on I eventually coaxed 430 hp out of it. I figure those numbers speak for themselves.
