If you're all assembled you could take off a pair of springs w an on engine valve spring compressor & put on the light springs & experiment a bit. iirc one of the cam companies once you had that dimention in hand had a spec sheet listed that would tell you which one(s) of their cams would clear and you could probably cross that over to our MP cams
