It sounds like your ping is just on the transition from a high-vaccuum situation to acceleration. I'd stick a small allen wrench into the vaccuum advance and give it 1 turn counter clockwise and retest. This should make the vaccume advance go away a little faster.
If I remember right I set it at 32 deg total and I know I'm using the right port.
Inititially I had it too far advanced and then re-set it to 32 deg because it was too hard to start.
