They work great, although the glide may not be optimal for a car that heavy it will work and be just as or more consistent than a torque flite. They are simple and cheap to build. And since you have all the parts, and converter. I would use what i had, cause buying every thing is expensive.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
