Re: 273/318 heads
[Re: classof65]
#512165
11/01/09 12:13 AM
11/01/09 12:13 AM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
If you have a good set of 315's, let me know. They are, at least on a 273 in NHRA legal configuration, the equal of, if not superior to any other legal number including the vaunted 302's (which we are currently working with)
All I submit is this - the dyno is the dyno and the ET slip is the ET slip. 315's are a great choice for the 273. The odd angle of the bolts does cause a bit of a problem, but it is only a matter of some end mill modification to fix a later intake to bolt down properly.
Not trying to start a war or be ugly, but we don't get behind the wheel of a flow bench, it is only one tool and doesn't tell the whole story.
Peace, Rev. Mopar (Class of 65, 32 time IHRA and NHRA national record holder)
Hey Rev, if you need a set of 315's I have a set. I need a set of 920s for a Bonneville motor.
