The OEM nuts are a locking type nut(look for the identation half way down in the center on two sides ) the Mopar service manuals call for 55 FT lbs. on the stock 1/2 inch U bolts and stock nuts, no lock washers or flat washers from the factory, they are to cheap to use them or pay someone (in the UAW) to install them
