if someones rebuilt the coupler, id say the shoes are in backwards, yes it can happen, Id think alot of the movement is in the coupler, its splined to the box but not the column, buy a rebuild kit for 10 buck and start there...id look at the shaft, draw a line on it and the couple turn the wheel till it starts to move the gear see if your lines line up.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
