lacquer thinner,acetone,nail polish remover,mineral spirits,gasoline,kerosene,reducer will work just fine ,common sense helps not to cause any damage to the paint,
avoid scrubbing,scratching or applying pressure,never use scotch pad,nails,razors,putty knife,e.t.c. unless you're planning to repaint
