I am in dire need of GOOD information about the C.I # and year my hemi has been made. All i know is it came out of an old truck, it has no water ports in the fronts of the heads, doesn't have the built in bell housing(so not a 331), has dual single barrel holley "Governor" Set up, I took off the intake manifold assembly and the val. pan and found no numbers except a few on the back of the timing chain cover that disapear into the seam. I also found a W3 inside the block under val. pan. Any good free information you have, please help me out! thanks
