Re: 9.5" flywheel
[Re: Supercuda]
#488145
10/05/09 06:11 PM
10/05/09 06:11 PM
Posts: 20,225 Park Forest, IL
slantzilla
Park Forest, IL
Let's clear this one up right now.
The difference is NOT the outer diameter, which is all that matters fr a manual trans setup.
The difference is the inner diameter where the snout of the torque converter is supported.
This difference applies only to an automatic equipped car, not one with a manual trans. If you happen to have the early, smaller inner diameter crank and whant to run it with a later, large diameter T/C then you can machine the inner diameter out. If you happen to have a later crank with the larger diameter and you need to run it with a smaller diameter T/C then you need an annular ring to make up the difference. I believe Wildcat Auto sells them, among others.
I guarantee that the outer diameter of the register is smaller too. I have 3 small register flywheels in my shop now and they will not fit a later crank.
"Everybody funny, now you funny too."
