No, the /6 flywheel will not bolt to an LA crank. I think two bolts are off.As for the rest of the flywheel matching up (tooth count, pressure plate bolt pattern, etc) I dunno.
1 bolt is offset. I have a 340 flexplate on my Slant by elongating 1 bolt hole, so you may be able to use a Slant flywheel on a 273.
"Everybody funny, now you funny too."
