Are the tubes pinched for the spark plugs?
Some of them are. I've changed plugs twice since the install. Not too hard. The two things I've run into with them are -
I had to clearance the power steering box about 1/8" Basically I ground off some cast letters/numbers.
I had to buy plug boot insulators to keep from smoking spark plug boots on a couple of plugs. After I put them in someone came out with ceramic boot plug wires which I would try if I had to do it over again.
I have manual steering and angle plug Eddy's, so the Doug's are starting to look better all the time...
