40 current interior,,,after i get it back running,,i plan on going to more modern buckets,console and maybe a column shift,make a little more floor room,,,need to find buckets that will fit and not touch each other,,and allow for somne sort of console/arm rest type deal. ide like to find out how the modern chrysler follr shifts work,cable or linkage if i keep a floor shift i may use a pacifica console and shifter
