I put a set of 3400 lb super stock springs on my 70 roadrunner per Mancinni's suggestion.I dont make much power,just a 13 second ride and i want to order some rancho 9 setting shocks.The car sits pretty much in the stock position,not like the rear is jacked up had i put on the 3800 springs.Should i order the shocks for standard ride height or 1" raised?Thanks.
