Quote: You would think there would be a formula similar to the one used in shaving the intake to fit.
P2 = 7.500 - D/Cos(14)
P2 - Desired (new) push rod length 7.500 - Stock small block pushrod length D - Amount of height removed; Amount milled from heads + Amount shaved of the block deck + head gasket compressed height difference
