What are the heat shields you guys are referring to?
Oh, the muffler heat shields. I'm working on a T/A clone and they don't use those shields.
You can check your frame to see if your car used screws or rivets for the K frame splash shields. Mine used rivets, but if it were screws the hole would be stretched a little and I'd be able to see the cut threads like I can with the starter shield.
