Heat shields 3 each Starter splash shield 4 ? K frame shields 2 each Rear axle rebound bumpers 2 each
I count 16
2 on each on front splash shield or ? 4 Axle rebound bumpers take captive washer 1/4-20 bolts (4) Mine is 4 spd no spash shield. Rear heat shields should take 1 each on front due to rear portion of the heat shield attached to the tip hangers ?
So I would think total of 6 for 4 spd car and 10 for auto car. Bill, Get ready to take an order.
logan426
I don't agree....The rebound bumbers never used a 1/4 20 bolt, there would have to be nuts welded inside the frame rail which there isn't. The muffler heat shield require 3 each AND the rear muffler hanger....I guess you could omit the two that go into each frame rail if you're into rattles ![](/ubbthreads/images/graemlins/shruggy.gif)
Most 72-74 cars that I've restored used the screws on the K frame shields, but recently I've been finding pop rivits on the 70's I've been working on. I believe 71 would be the change over year.
I'm sticking with my first count. ![](/ubbthreads/images/graemlins/rolleyes.gif)
CHECK OUT MY NEW WEB SITE !
