Anyone else with tight fan clearence?
Will a short clutch fan fit?
The problem with the aluminum rads is that they are thicker than the brass ones. I used a mancini rad that looks very similar too yours. I bought their shroud but it needed rework. I used their 22" rad as at the time I didn't know about the aftermarket yokes you can buy. It still cools fine.
I used a 6 blade fan on a jaguar clutch (it's the only one that would fit), however, it did not cool very good at idle. I replaced it with a 6 blade solid fan with a 1"spacer which cools well at idle.
