One of the sway bar brackets on the frame of my 72 Fury Wagon has broken the welds.
If I choose to take the sway bar off the front,will I notice any difference in handling?
Is it safe to remove it?
If the broken sway bar bracket is the end link you will not notice a difference with it off because it is not connected anyways.
Now if you were able to connect it you would notice a difference.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
