So what is the best set up for a 440. Trying to do it on not a ton of money so any good places to pick up cheap parts. Was going to put together motor myself but send it out for any machine work.
If you on the cheap, you may want to re-consider swapping out the /6. Cheap being relative, I have not found a way to install a RB in my 67 Belvedere for much under $2000 and I already have an engine, trans and K-Member.
That being said, you will find it much easier to swap an A engine to this car without changing the K-member - I am fairly certain Schumacher makes a /6 to A mount for a B body.
In the end: What do you want from the car?
If it were mine I would put a very mild A engine in it and paint it to look like a vintage police cruiser.
67 Belvedere II
225 Slant Six
383 on the stand
The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants. - Thomas Jefferson
