If the VB has compression braking in 1st gear it's LBA and the band is applied/released on each 1-2 shift cycle. The stock servo needs to be rigidized and a heavier spring installed but this might have already been done when the VB was installed.
thanks. yes, the VB came with a much stiffer spring and i purchased the heavy duty retainer for it
