Quote: It will likely work fine for now, try to minmize the burnouts in reverse & expect to replace the band & drum when it comes apart...
seems to done the trick. the car is multidirectional again. i can go forward and backward!!
I wonder how long it will last? I saw they make and sell some longer struts in the my Torqueflight Transmission handbook that are used if the drum is machined. I'm thinking I should pick them just in case.
