everything worked befor, i had a bad carb, put a new one on started it timed it then when i turned it off to tighten the dist. down it wouldn`t fire back up,also the ing switch works whenever it wants to. the guy i got the car from had the relay jumped with a push button, it is a 4 prong balast.
