I forgot is it a 2 or 4 terminal ballast? if it's a 2 pin pull both sides off & see which one has fire when you turn the key on. The downstream side will be the other side. Good point but I wanted to confirm that everything is good & it WILL run but to speed things up trace upstream from the "point" on the ECU pentastar connector to find the open
