That looks like a very do-able kit. The Master
Power kit requires you to send them youe axle and wait 2 weeks. By the time you ship it there and back, could almost be a month to get them back.
Tapping out those 5/8" fine thread holes requires a bit of effort. The spindles are not the most simple things to hold in a vice so you get the threads cut straight, and the required drill and tap can add up pretty quickly. But it is do-able, and those disc brakes work well. Gene
